Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: JD 5105 condensation
04-05-2013 08:10:44
My opinion is that plastic sweats less than steel because sweating is caused by something remaining cooler than the temperature of the environmental air. Plastic being lighter can follow easier as it takes fewer BTU's to make the temp change.
What is your fuel source? Is it on farm storage or delivered from where? Do you fill from a tank in the back of your p/u? Do you have a water separating fuel filter on your supply line like Goldenrod co. offers? I'd suspect the source as where the water originates.
Additionally, when you run your tractor, do you let it come up to normal operating temperatures, or do you just make short runs especially in the winter?
Ron Scott
04-05-2013 09:48:03
 Re: JD 5105 condensation in reply to Texasmark1, 04-05-2013 08:10:44
I fill the tank from back of p/u and buy from diesel dealer we have here. I have talked to another guy who has a 5205 and he buys from the same diesel dealer and has had to problem with condensation. I have a water separator on fuel filter and change fuel filter 4 times year due to condenstion. When I run the tractor I do let it get to normal operating temperature and in the winter I use the blade to scrape snow from our drive and several others. In the spring and summer I use the tractor for bush hogging and plowing the field. This afternoon I am checking the fuel vent to see if it is stopped up. JD has been no help and it has been there three times to be fixed along with new injectors installed.
Tx Jim
04-05-2013 11:02:49
 Re: JD 5105 condensation in reply to Ron Scott, 04-05-2013 09:48:03
Normally if tank vent is plugged then there's a lack of fuel flow causing engine to run poorly or die. Are you transporting your fuel in a 55 gallon drum?
