329 combine engine - low oil pressure
raycefan
New User
This message is a reply to an archived post by cooney minnie on August 12, 2012 at 10:42:11.
The original subject was "329 combine engine low oil pressure".
low oil pressure jd 5410 tractor, bearings ok, oil pum p and tubes ok, replaced pressure spring, still no answers,maybe oil cooler leaking, going there next. any ideas, thanks
I have seen a few of these models have the drive gear slip on the oil pump shaft, they are a taper with "no" key, when I repaired them I went with a new shaft/gear, scuffed it up a bit and loc-tited them...
