We got the 4020D running tonight, only a couple of small leaks that are fixed now.
The engine has the enhanced compression pistons in it. We set the timing at 10 BTDC, but it loped a little at idle, and really sounded like it wanted to detonate, so backed that to 5 BTDC and it quieted right down and the idle smoothed out.
Have you seen that much difference in timing between standard and enhanced compression.
