Loader for NewGen tractors
FarmerZeb
What JD loaders will work on the infamous JD2010 and also work on a 3010/3020? (provided one had the correct brackets for both)
are there any?
thanks
paul
The model 35 made in 61" had mounting for both 2010 & 3010; In was JD first welded box beam loader boom frame. & welded booms broke up alot..A better choice is 36A same mounting fit 2010 & 3010 , had ajustable frame back to axle,for dif. length tractor frames, & much improved welded boom...
