TractorLinks.com
Show Parts for Model:
4520 circuit breakers
jelfert
04-05-2013 01:36:44
My circuit breakers keep tripping when I run my lights (JD 4520). Is there a fix for this? Anyone ever convert to relays? or fuses?
Cliff Nelson
04-05-2013 05:32:47
 Re: 4520 circuit breakers in reply to jelfert, 04-05-2013 01:36:44
The circuit breaker is doing it's job. Look for rubbed wires in the lighting circuit. I have found on several that they will rub through if the harness is touching the hyd pipes under the dash. Wouldn't hurt to try a different breaker to be sure as someone else said.
Tim S
04-05-2013 06:16:27
 Re: 4520 circuit breakers in reply to Cliff Nelson, 04-05-2013 05:32:47
To add to what Cliff stated make sure the breakers have a clean tight connection, a bit of rust and looseness allows heat to build up making the breaker trip prematurely..
Jethro Lilley
04-05-2013 03:22:22
If the 4520 is original then the wiring is over 30 years old. The circuit breakers may be doing their job... look for a short where the wire has rubbed on metal for three decades. Try another breaker in that circuit as I've had those little suckers go bad.
Tx Jim
04-05-2013 03:43:08
 Re: 4520 circuit breakers in reply to Jethro Lilley, 04-05-2013 03:22:22
I second what Jethro stated.
jelfert
04-05-2013 05:58:38
 Re: 4520 circuit breakers in reply to Tx Jim, 04-05-2013 03:43:08
I just had the wiring system gone through and new lights installed. The old circuit breakers/relays were used.
