jd 630
dallas ivory ot
04-02-2013 14:17:29
i bought a 630 2yrs ago that had not been run in 3yrs i got it home and replaced all filters and fluids when i got to the radaitor there was oil in the anti freeze so i thought maybe a blown head gasket so i put this stop leak product i had used on my 730 with good results i filled with water and run it all summer and drained water in the fall with a little bit of oil in the water so i thought i had a blown head gasket that my stop leak couldnt fix well i had my neighbor tear it down and head gasket is not blown and the block is not cracked has anyone had this problem
Canadian Ken
04-02-2013 20:43:10
 Re: jd 630 in reply to dallas ivory otter lake m, 04-02-2013 14:17:29
I have been told that the 50/520/530 heads had steel tubes for the push rods that would rust through allowing oil and antifreeze to mix.
I don't know whether 630 heads were built the same way. I sure some one on here is more knowledgeable on this than me.
Ken
