Rob Maloney
Another follow up to an ongoing problem. Have slow 3 point lift, but have discovered that if I push the SCV handle to activate, the 3 point will raise ONE time at full speed. Then you have to push the lever to neutral to get it to raise the 2nd time at full speed, then back to activate position and so on. When it "activates", you can here the engine labor some. Do I have an internal leak? Loader operation sppears to be unaffected. Is this a drawn out problem? TxJim told me I could disconnect the SCV valve and probably cut out the problem all together. I"d like to fix it if I could, put sm tired of dumping $$$$$ into this 2630. Thanks.
