Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 2630 3 point-SCV problem
Tim S
03-31-2013 16:59:10
Enough of that kind of talk,,,your problem is most likely in the flow valve in the left front corner of the rock shaft,,when you work a other function you make a slight pressure drop in the system this will let the flow valve flex a bit in the bore,,there are some things that happen here that i don"t under stand,,and I have been dealing with one off and on the last week...I don"t like these systems much,,but I like Orange tractors even less ....
Tx Jim
03-31-2013 17:13:01
 Re: 2630 3 point-SCV problem in reply to Tim S, 03-31-2013 16:59:10
Tim
I never think about that valve(parts key #10). It's actually located in the RH frt corner of RS housing. I don't ever remember it being a problem when I worked for dealer but the JD utility tractors were like me a lot younger back then. But it's easier to cap the scv supply line as a diagnostic step that to mess with that flow valve.
Hey what's wrong with Orange tractors? I own one and something must be good about them as I see a lot of new Orange tractors in the countryside. I know one thing my Orange tractor will go forward/backward,operate the frt end loader & 3pt without the aid of electronics.
This post was edited by Tx Jim at 17:20:49 03/31/13 2 times.
Tim S
03-31-2013 17:39:29
 Re: 2630 3 point-SCV problem in reply to Tx Jim, 03-31-2013 17:13:01
Yes I got my right and left mixed up again,,Darn it,,I knew you were trying to help him Isolate the problem, and that is always a good idea, I will tell you what will happen in his case, with out a loader,(which I don't think he has a loader on)When he caps the SCV the hitch will go up slow, it will have nothing to create a pressure drop,,I was just through this Wednesday,,when you work the SCV it creates a slight pressure drop, then the hitch comes up fast ....And I can't tell you exactly what to do about it "YET" Darn it,,But I think it's in the flow valve in the hitch..
Tx Jim
03-31-2013 18:36:51
 Re: 2630 3 point-SCV problem in reply to Tim S, 03-31-2013 17:39:29
Tim
I agree with you I just never personally witnessed the valve you referred being a problem. Plus you do this on a regular basis and I've been away from a dealer a long time.
