felt greased seal
Mother Deere wants $40.82 for seal # A380r !
This seal is used on rear axle of an unstyled JD AR.
That means for two felt seals $81.64 !
Does anyone out there know of someone/company that make felt
seals.
Thank you !
The felt seal is only to keep dust out of the outside bearing. Common practice to wash it out and reuse. K&K might have new felts.
(quoted from post at 13:20:13 03/31/13) Mother Deere wants $40.82 for seal # A380r !
seals.
Thank you !
got mine for my unstyled A from Davenport Tractor for $11.00 each. Should fit your AR also.
http://www.external_link.com/p-257-rear-axle-felt-for-john-deere-a-50-520-530-with-88-inch-tread.aspx
New rear felt seals and retainers can be purchased from Davenport Tractor, Davenport, Iowa
Both rear wheels on an A two seals two retainers was about 90.00
