Power Lift vs. Power Trol units
elkcagg
We have a '47 B with a power lift unit (2 pedals above platform) & I want to put on a Power trol unit so we can have variable up & down with the rockshaft plus remote cylinder usage. Are the bolt patterns the same for the same units? I figured I'd ask first here before I waste any time trying. Thanks
I did the same swap on my 1946 A. It's a direct bolt on. Try to get the mounting bolts also. Seems like one or two of the bolts are different length.
I did this last year on my 1945 model A. The change over will be a perfect match between the two units. Remember to get a new gasket and a new copper flat washer for the one bolt that uses it. Ray
