Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: oil filter O-ring JD A
Carlyle Hoffman
03-28-2013 15:27:25
There are 2 different size (O) rings, one for JD 620s and up and 1 for below,such as A,s & ,B,s . The larger one will never fit. Make sure You have the smaller one. Make sure (O) ring race way is down to STEEL.*CHECK*, no old rubber. Now stretch new (O)ring and push up in the grove. Now carefully take 2 narrow screw drivers, one gently held against the rubber and TRACE around on the rubber with the other and the SQUARE rubber will gradually FLIP over CORRECTLY as you work around the (O) ring. Works every time, no hassle.You will never place it correctly with your HANDS. such
Kent Petersen
03-28-2013 17:21:04
 Re: oil filter O-ring JD A in reply to Carlyle Hoffman, 03-28-2013 15:27:25
Guys the correct team for gasket type ring is sq. packing it is not an o,ring it is the same size for all the two cyls. made in waterlou but does not fit the model h the larger packing that comes in some will fit filters is for the 3010 thru 4020 models deere does not put packing in the box with filter
