Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: oil filter O-ring JD A
03-27-2013 19:50:54
I know it sounds dumb but did you get the old one out? I had one that I used for years and changed the oil several times and didn"t realize that there was a old o-ring in there. always took one out, but then one just the last time i changed it it leaked and i had my uncle look at it and there was an old o-ring in it... you couldn"t even tell it was there. I would try digging around in the grove with a screw driver to make sure its clean
03-27-2013 20:48:09
 Re: oil filter O-ring JD A in reply to 48JDA, 03-27-2013 19:50:54
I know what you mean, have never had that problem on this tractor. Did it once on a minivan though.
I even take a screwdriver and rag and clean out the groove really well.
The groove is flat at the bottom and V-shaped on the sides. The o-ring that comes with the filter is square. Just doesn't ever seem to set in the groove in a way that it will resist gravity long enough to screw on the cap. If it sets on the cap it slides sideways as you screw the cap.
I tried the dab of grease things once and it didn't help any, just made the 0-ring harder to hold on to for the second try.
Cliff Nelson
03-28-2013 05:21:46
 Re: oil filter O-ring JD A in reply to dmiller, 03-27-2013 20:48:09
It sounds like there is an old packing stuck in the groove yet. The groove should be square and deep enough that the new ring will fit completely into it. Should not be a balancing act to install.
Mike M
03-28-2013 05:29:05
 Re: oil filter O-ring JD A in reply to Cliff Nelson, 03-28-2013 05:21:46
I agree.It does sound like old one is still in there as that groove is to be flat in the bottom. I've had to take a sharpened screwdrive and use as a chisel to get the old ones out. I always install a new packing whenever I change the filters.
