MT, HYDRAULIC FLUID TYPE
M. Davis
New User
I"m not having luck finding any 10W oil for the hyd. system on my MT. What can be used in the place of 10W oil.??
20wt non-detergent is perfectly fine...
In TX, The Colorado Cty Oil Company sells it by the case, 12 per case...think it takes 4.5 pints or so...just do not use something with a detergent/agent in it bc it will foam-up on you and that is not good in the pressurized part [valve-housing] side of the TOM
regards
tstex
Thanks for all the good info. Tractor Supply here might have it if I ask the right person that works there. If not, 10W-30 might be my route. Again, thanks to all.
