Oil weights
jd4000
For a 720 gas and a 830 (2 cyl):
I assume it is no problem if I use Hyguard in the power-trols.
Also ok for the powershaft reservoirs?
Calling for SAE 90 in transmissions. Is the hyguard ok, or is it too thin. Know the newer oils now have a lot different additives than back then.
Thanks
HYGUARD WILL LUBE JUST FINE IN THE TRANS ON 720 & 830 but if you work it hard for long time it may get to hot as there is no cooler on these tractors
It's fine in hydraulics and for the powershaft clutch.
It wouldnt be my first choice in the transmission. It will work but it's awfully thin and it's also way too expensive. Gear lube is cheaper and will do a better job for you.
