Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4640 runs just will not shift in any gears with out diei
Tx Jim
03-27-2013 09:31:24
Does engine idle at 800 rpms? If so will engine continue running with clutch pedal depressed while trans is in gear? If not it sounds as if trans is shifting into 2 speeds at the same time or differentioal is locked.
Jeffh
03-27-2013 09:47:51
 Re: 4640 runs just will not shift in any gears with out diei in reply to Tx Jim, 03-27-2013 09:31:24
BAtteries were dead when I tried to start it. I am going back this weekend to start it and test for my self. I assume from the way the seller told it. that the engine does idle but either pulls down and dies when clutch is all the way out.
long green line man
03-27-2013 10:33:24
 Re: 4640 runs just will not shift in any gears with out diei in reply to Jeffh, 03-27-2013 09:47:51
Sounds like park lock is not releasing ; or shift linkage is in reverse & foward a same time...
Tx Jim
03-27-2013 11:17:53
 Re: 4640 runs just will not shift in any gears with out diei in reply to long green line man, 03-27-2013 10:33:24
I did forget the park lock as a possibly of being the problem from the cable being stuck
Jeffh
03-27-2013 10:52:30
What is your recommendation? I have looked around on the net on pricing for rebuild shift packs and I really don't want to spend 7000 in parts. I have never worked on a power shift trans I have syncro and quads. I've tried to stay away from the ps. If it is the park lock will a person be able to pull the tractor? When the guy bought it he had to be able to load it and unload it?
Tim S
03-27-2013 11:02:28
 Re: 4640 runs just will not shift in any gears with out diei in reply to Jeffh, 03-27-2013 10:52:30
I would never recommend buying a Power shift tractor that is in need of repairs,, they can have some expensive surprises hidden inside..
Jeffh
03-27-2013 11:15:20
 Re: 4640 runs just will not shift in any gears with out diei in reply to Tim S, 03-27-2013 11:02:28
that is what I am afraid of
Thanks
