TractorLinks.com
Show Parts for Model:
Re: John deere tractor will not go into gear
Tx Jim
03-26-2013 03:52:39
The trans pump oils the trans gears & shafts plus supplies oil to frt hyd pump. It's possible that depressing foot clutch pedal could cut down on lubrication causing hard shifting of syncronizers(but I've never personally witnessed this condition). Another possibility is worn syncronizers &/or shifting components. It also could be a traction clutch with incorrect free travel setting or a warped clutch plate BUT I still stand by that the problem isn't related to the frt hyd pump or it's prior repair.
Kasey Mcwherter
03-26-2013 05:05:22
 Re: John deere tractor will not go into gear in reply to Tx Jim, 03-26-2013 03:52:39
I Just want to locate the problem to fix not point fingers, but I can physically use this tractor for long periods of time with zero shifting problems until the front loader is adjusted. I'll give the mechanic a call and have him pull the floor plate and look into the transmission and see what he sees. I have a feeling he might find a bad synconizer or one that is starting to wear. If everything looks to be in working order, it's time to evaluate my hydraulic preasure and fluid levels because the dealer did not refil this which means they probably didn't flush the lines and or change the hydraulic filter. I'll look at my paperwork, but i'm pretty sure it wasn't done. Thank you for your help. I'll try to post a reply when we find the problem.
