Are cracked blocks for unstyled A's worth anything?
I have two blocks for unstyled A's that are cracked. One is cracked in the bores at the top of the cylinders. This one would need to be bored at least .045 over if you could get the cracks repaired. The other one the bottom of the block is cracked all the way around, probably had water left in it that froze. This one would need to be sleeved, I don't know if the bores are cracked since it hasn't been magnafluxed.
They don"t make them any more, so if it can be repaired,to me
its worth fixing to use,save it,or sell it as is,just my opinion
