On my JD 2020 I removed the rockshaft housing to replace all the 0-rings. I forgot to mark the FULCRUM connector to the 3 pt control lever. There is a pin that connects this to the control arm. I have 2 choices, fat side up, or fat side down. So I though I"d get some advice from here. It"s hard to tell from the parts diagram.
Part #AT19840.
Thanks,
Todd
I happen to have one here with the lid off , with the 3pt handle in the "down" position it looks like the thin side up,,here's a pic.
Thank You Very Much! I also had the right hand Tabe broke of the cylinder, which I found odd, since the pressure is at the top, but I was able to grind and weld the mount tab back on. Also, the spool valve leeks, and after taking it apart, cleaning it, it still leaks, so I guess you have to change the spool valve and the lower seat? I am guessing this would cause the lift to settle after tractor is turned off? Thanks for the info...
Todd
(quoted from post at 08:21:00 03/25/13) I happen to have one here with the lid off , with the 3pt handle in the "down" position it looks like the thin side up,,here's a pic.
Tim
I would have thought you would get tired of correcting my mistakes. :wink:
Thanks for correct info.
Jim
