Is it possible to simply BYPASS the svc remotes on a Deere 2630? Having some complications with the SVCs causing slow 3 point response. Second, if not, is a complete rebuild on the svc remotes the easiest way to cure a potential leak?
If you don't need the use of th scv then yes just disconnect the line at the jic fitting on the pressure control valve and install a cap. If you choose not to cap fitting here is a plug that is intended for tractors without scv.
R39112 PLUG ADD 6.01 USD
