JD front mounted snow plow
Stuart
I recently bought an original JD 8ft snow plow that fits most 2 cylinder tractors. I would like to know what model it is. It uses a cylinder in front mounted horizontal to lift it. What other descriptions are needed to ID this plow. Thanks for all the help
Do you have Adobe Acrobat Reader installed? Only one I know of for the 2-cylinders is the ABG90. Doesn't explain the hydraulic lift, though.
<img src = "https://photos.yesterdaystractors.com/gallery/tphotos/a1757.jpg">
It could be an 82 blade for the New Generation if it is hydraulic cylinder lift. The blade for the 2 cylinders was cable lifted from the rockshaft.
I just found out that it is a new generation lift but will fit the older 2 cylinders. It is an 82
Looks like a nice outfit!
<img src = "http://toytractortimes.com.s3.amazonaws.com/messageboard/images/members/3824/large-38R9ULD4OK.jpg">
I painted a 82 on tuesday for a collecter,we sold it for $1000.We have another one that we use on our 2510.The same fellow bought a 46A laoder that we painted yesterday for $1500.
