TractorLinks.com
Show Parts for Model:
Re: JD 2520 engine TimS?
DaveH IA
03-24-2013 09:13:53
Just to add to the good advise --while the pan is off --put a pressure test pump on the radiator and watch for leaks -- internal and external
Tim S
03-24-2013 09:21:41
 Re: JD 2520 engine TimS? in reply to DaveH IA, 03-24-2013 09:13:53
Ooh yes Dave I was thinking that and forgot to post it, this could prove the liner seals, I'm still thinking there seems to be a lot of water in her other than condensation,,but it is possible...
tomstractorsandtoys1
03-24-2013 11:50:08
 Re: JD 2520 engine TimS? in reply to Tim S, 03-24-2013 09:21:41
How much pressure should he put in the cooling system? He plans to work on it tomarrow.
Tx Jim
03-24-2013 09:45:02
I agree on the large amt. of condensation.
03-24-2013 11:56:28
 Re: JD 2520 engine TimS? in reply to Tx Jim, 03-24-2013 09:45:02
He found about the same amount of water in the hyd oil but it seperated out more and was not mixed with the hyd oil.It will be flushed and new oil and filter added before starting.He will pull the trans. screen as well.
Tim S
03-24-2013 13:13:29
 Re: JD 2520 engine TimS? in reply to tomstractorsandtoys1, 03-24-2013 11:56:28
You can go to the 15-17 lb. area safely..
MARKS87
03-24-2013 14:19:29
 Re: JD 2520 engine TimS? in reply to Tim S, 03-24-2013 13:13:29
Crank the engine with the fuel off to build oil pressure for 20 seconds or so-or put a guage on it & when you have 20psi let it have fuel. you'll have the bearings full of oil before there's a load on them.
