1010 Diesel - Hydraulic filter?
My 1962 1010 has a loader and a backhoe attachment on it. The reservoir is in left "riser" for the loader. You unscrew the breather cap and fill fluid there. I can not for the life of me find the hydraulic filter on this thing. Is it possible that it is inside the riser/reservoir?
I'm 99% sure your 1010 won't have a factory in stalled filter ,anywere in system.. If it's IND. 1010 w/o rockshaft it won't have a tractor reservoir ether.. It could, or should, have a add on filter on return line near reservoir in loader frame... Do hyd,s. use pto or tractor driven pump?
long green line man
I checked the parts manual for a 1010 ind. and didn't find a hyd filter listed. It appears the model 710 loader fits the 1010 ind tractor.
(quoted from post at 19:15:37 03/22/13) Thanks Jim ; "right on" That's the page I hoping to see; I don't know my Ind. loader model # well....
Me not being very familiar with industrial equipment caused me to have to download a few ind loader parts catalogs until I found the correct one. That's one advantage of the old catalogs in PDF as they have a photo of the equipment &/or tractor on the first few pages.
Wow, look at that, guess I should replace that filter, eh? The loader is a model 710 for sure
Maybe I'll even get some power back to the backhoe and the loader, should be interesting to see if there is a difference. I can imagine that filer is very dirty.
Thanks guys!!
(quoted from post at 10:59:31 03/25/13) Wow, look at that, guess I should replace that filter, eh? The loader is a model 710 for sure
Thanks guys!!
I don't see a filter? is it inside the resivor?
