TractorLinks.com
Show Parts for Model:
Re: 1973 JD 4230 sleeve pulling
donjr
03-19-2013 21:02:58
You can make a sleeve puller fairly easily. Make a 'top' piece from a piece of 1/2" steel and a 1/2" hole in the center. Weld 3 legs of heavy bar stock about 4" long and wider than the top of the sleeve to the plate. Make a bottom plate of two plates, one about 3/16 to 1/4" larger than the piston bore, and a second plate about 1/8 inch smaller than the bore, and about 1/2 to 3/4" more narrow than the bore, rounding the ends to the approximate curve of the sleeve. The small plate will keep the large plate bottom centered. Using a long bolt or piece of all-thread, slide the bottom plate down through the cylinder and hook it on the bottom lip or the cylinder. Place the top bracket over the bolt and snug it up, making sure the legs are on solid block casing, and tighten the bolt slowly. It should pop out easily.
