Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 60 automatic fuel shutoff
ben70b
03-19-2013 12:53:26
i was wondering if that was the ticket, just plumb a valve into the fuel line huh? what do i do with the other two smaller fuel lines?
BushogPapa
03-19-2013 20:57:02
 Re: 60 automatic fuel shutoff in reply to ben70b, 03-19-2013 12:53:26
Besides the Fuel shut-off valve, you would be wise to plug the Oil Pressure line, to prevent fuel getting into the crankcase through the oiling system... I take the Brass fitting off and solder it closed, then re-install it.. Then all you need is a small wedge to slip between he fuel tank and the "Tickler-Button" to get fuel flow.. Ron..
Tim S
03-19-2013 13:20:56
You need to go to Tractor Supply and get a different fuel bowl with 3/8" thread, then get a 1/4" ball valve. Do away with one oil line and run one from the oil supply to the gauge. I put a 1/4" ball valve in so it is easy to turn on/off,,those darn little "Tee" handles are tough on your fingers.
