Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 1942 JD Model B Oil Pump Drive Coupler
Mike M
03-19-2013 12:15:33
First make sure that it is not left over parts from a previous repair.
If yours is indeed broken off right now then you will need to get a coupling and then drop the outer cover and shaft down to install it.Get a new gasket from Deere. I perfer a good used old style couplings so they can snap if ever needed to in the future. The replacements are heavy duty and likely won't give before the gears or shaft.
Brandon K.
03-19-2013 17:24:45
 Re: 1942 JD Model B Oil Pump Drive Coupler in reply to Mike M, 03-19-2013 12:15:33
Can some one give me some pointers on removing th oil pump and changing the drive coupler. I understand the cupler goes onto the pump shaft but what does the other side go on to? What drives the pump shaft? Thanks
03-19-2013 19:03:10
 Re: 1942 JD Model B Oil Pump Drive Coupler in reply to Brandon K., 03-19-2013 17:24:45
The other end of the coupler goes into the worm drive on the camshaft. You may need a helper to guide the assembly together. Ron Mn.
