Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: JD 70 flywheel???
Hugh McKinney
03-18-2013 21:12:00
I had the same question about four years ago when I inherited my Daddy's JD 70, since he was deceased, there was no one around to ask. I finally figured out that on the flywheel cover, there is a small "viewing cover" that you can remove, and looking through that small hole, you will find that there is at one point, a "bump" on the flywheel about the size of the hole in the cover. You take some chalk and mark the bump to make it easier to see with the timing light. Once you have it started, or at least rotating, with the timing light connected to the left side (flywheel side) cylinder spark plug, move the distributor one way, then the other, until the chalk mark "fills" the hole in the cover. I used different colors of chalk to denote BTDC and ATDC, because at first it was so far off that I couldn't see my chalk mark at all through the viewing port. Good luck.
