Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 620 carburetor problem
jd2cylman
03-15-2013 18:29:07
Well, there are 2 possibilities. First, check for adequate fuel flow to the carb. If you have good flow, check the intake manifold gasket. Spray a little ether around the intake to head joint. If the rpms pick up, the gasket is leaking air, which leans out the engine, thus the need for a little choke.
Good luck.
Adrian
JD435
03-15-2013 22:33:41
 Re: 620 carburetor problem in reply to jd2cylman, 03-15-2013 18:29:07
2ND POSSIBILITIES IS CHECK THE INTAKE MANIFOLD. i HAVE SEEN THEM GO TO PIECES INTERNALLY AND MIX AIR FROM THE HOT - COLD SIDE OF WARMER ,AND MAKE THEM RUN LIKE THAT . LOOK IN THE CARB SIDE AND THEY DECAY AT THE BEND .TOOK ME MONTHS AND A LOT OF HEAD SCRATCHING TO FIND IT .GOOD LUCK JD435
