TractorLinks.com
Show Parts for Model:
Re: 4020 hydraulic problem with loader
Roger in Iowa
03-15-2013 07:04:21
Both the original three spool valve and the new one are/were convertible. Problem occurred with the old valve too.
I am thinking there is something wrong with the tractor side of things.
Would a clogged or partially clogged filter or screen do something like this. Why would you have to feather the valve it it work okay, except for down. When moved to full stroke of valve the hydraulics DIE. Like something is telling the front pump not to pump at all.
When at 1900 standby the front pump does go quiet.
Thanks for any input/help. Will remove return hose and check for flow, but do not believe there is any as front pump goes quiet.
Tx Jim
03-15-2013 09:15:40
 Re: 4020 hydraulic problem with loader in reply to Roger in Iowa, 03-15-2013 07:04:21
Removing the return hose as I previously outlined will establish if valve has closed center plug installed correctly. Have you thought about plumbing loader valve into another tractor with closed center hyd's to determine if hyd problem persists??
Roger in Iowa
03-15-2013 10:32:26
 Re: 4020 hydraulic problem with loader in reply to Tx Jim, 03-15-2013 09:15:40
No. Unfortunately hind site is 20/20. Harder to do now since plumbing is hard wired so to speak.
Thanks.
