john deere 420 standard transmission rebuild
mkr100
Im a little stumped on the service manual directions on setting the bearing load on the pinion shaft. It had several shim behind the race. What the easiest way to get this right? Second there was a seal on the back of the bottom shaft. Whats its purpose as the gear oil free flows through both compartments. I might add i dont see that seal in the parts book.
Found my noisy bearing. It was the two needle bearings on the top shaft. They were almost rusted to the point of not turing at all. Now to my question. How do those bearing get oiled?
