4020D synchro oil dipstick
Kris A NC
My father-in-laws 4020 has what appears to be a 4020 gas
dipstick on it. It looks like a plus sign with the dipstick screw
coming through the top and it doesnt screw into the tube in the
block. Does anyone have a suggested fix or have a dipstick
laying around they want to sell? It feels like the cap i currently
have is too small and just spins on top without catching the
threads. Thanks for any help.
Kris A NC
What year is the 4020? Those prior to 1969 had the cross-type grip on top. My 64 has a cast steel top, my 68s have a different metal, maybe aluminum. As for it not threading tight, have you checked the treads? More than one has stripped out over the years.
New ones are available from Deere.
If you post a pic and the serial number, someone here will be able to tell you if you have the right one.
Coonie
Thanks for the reply. The serial number is T213R 157439R. Its a '67 model. I have a feeling it was "switched" since it was purchased at auction. The part number on the bottom of the cap is R26175R. I have attached a picture of the cap on bottom and a picture of a different cap on a gas model OF A DIFFERENT TRACTOR with the same cap as on the diesel.
Same cap different tractor
BFC9C18F-4483-4F62-99C5-D561530127E7-17039-0000198CC1EC481B.jpg"
Part number under the cap I have.
7FCDCC5B-AEE2-4B60-B3C0-5775B3F97B00-17039-0000198AB20D2171.jpg"
Thanks for the help
Kris A NC.
Without looking at the part number, I'd say my 68 4020 has the same cap. I replaced mine last year as the threads were stripped, and the replacement part looks identical to the first. And the threads were good on the new one!
I think you probably have the right part with damaged threads.
good luck!
I will take a closer look tomorrow. Thanks for the help. If anyone else has .02 to add by all means please add.
Thank you,
Kris A NC.
My original 4020 engine had that style cap and it's threads were striped to it didn't look like it but they were I think you can get a new piece that goes in the block from deere
4020 parts catalog < SN 200.999 only lists one screw in dipstick and
1 screw type tube.
AR40511 DIPSTICK 1 (SUB FOR AR32565 OR AR34917) (USE WITH R41883) (THREADED TUBE)
R41883 TUBE 1 (THREADED) (SUB FOR R40603)
Part Number: AR40511
Part Price: 91.79 USD
Description: CAP, OIL FILLER, WITH ROD
Specification
Weight 0.62 LBS 0.28 Kg
Grip Type 1
Cover Type E
Size 1.500 IN
Overall Length 11.118 IN
Length - To Full 9.354 IN
Full Mark 0.882 IN
Blade Width/Diameter 0.250 IN
I have a latter engine now and it has the rubber plug type
that's what I meant I can remember growing up using plastic
bags around the tube to keep the cap tight .. we was po folk
