TractorLinks.com
Show Parts for Model:
Re: John Deere B axle Seals? Best place to buy?
JohnDeereJimOhio
03-11-2013 13:16:44
I"f u could give me the part number if really appreciate it do they have the felt washers as well?
patsdeere
03-11-2013 21:57:48
 Re: John Deere B axle Seals? Best place to buy? in reply to JohnDeereJimOhio, 03-11-2013 13:16:44
Ok, so the part # is 23710. I crossed the 2 different part #s over from deere and came back with 2 different seals. I took both numbers to Napa to see the difference the owner told me that the only difference is a dust seal on the actual seal. Since there is no dust, you can get the cheaper ones. Mine were $12.99 each. Now I haven't put them in yet, but don't see any reason they won't work.
In terms of the felt seals, like someone else said give them a good washing out. All they do is keep dust out of the axle.
When you pull the rear axle to do the seals (I hope you know they are on the inside of the axle next to the bull gear) don't forget to mop out the oil from inside the axle. Otherwise you might think it is leaking again.
Have a good time. :)
Sterling in Mo
03-21-2013 18:51:09
 Re: John Deere B axle Seals? Best place to buy? in reply to patsdeere, 03-11-2013 21:57:48
That is the part # for the axle seal on the in side of the axle correct ? Not the felt washer on the outside of axle .
JohnDeereJimOhio
03-12-2013 15:39:36
Ok thank you very much for letting me know..
Maark
03-11-2013 16:15:48
Just wash the felt washer out in gasoline, let them dry and reuse them..
