Need help-Behlen road gear
Tominwi
I have a Behlen RG kit on a 38 John Deere A. I have a guy interested in it and I'm willing to sell it but I don't know what all goes with it. I assume there is a shaft or two that has to be switched out? Any help is greatly appreciated. Thanks
If you pull the cover off the roadgear unit you will see two gears. The two shafts that these gears are mounted on are the two shafts that need to come out if you are selling the unit. It requires keeping track of all the parts mounted on these shafts as you remove them if you are going to replace these shafts with the shorter stock shafts. I have installed one of these units on both the model A and B. Good Luck!
