850 PTO SHAFT
TIMAR
Have a little 850 with the Yanmar in it in the shop. Serial number is missing from the tractor and need to know which shaft he needs since there are 2 depending on the ser. no. Can you tell by the engine ser. no?
No longer availible from JD but salvage yards have them. Missing some splines, but was wondering if a machinest could build it up and re-cut or would it lose its hardnest?
I know that there is a serial number break on 850's where the early ones had a transmission driven pto and the later ones used a 2 stage clutch for a live pto. This may be what differance you ask about ?
