Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: JD 620 Tach drive
03-03-2013 17:28:12
Scott have you done this repair I'm wondering what it takes to replace the gears? Is the repair straight forward to do?
Scott 730
03-03-2013 18:39:50
 Re: JD 620 Tach drive in reply to RMOMN, 03-03-2013 17:28:12
RMOMN said: (quoted from post at 20:28:12 03/03/13) Scott have you done this repair I'm wondering what it takes to replace the gears? Is the repair straight forward to do?
Replaced gears in my 730 diesel. I would guess the gassers would be a similar job. I had to pull the governor shaft out of the housing to replace the drive gear on the shaft. It would be wise to replace both gears. Not a good idea to mesh 1 new gear with 1 old one.
This post was edited by Scott 730 at 18:44:37 03/03/13.
Canadian Ken
03-03-2013 18:27:34
I replaced the gear on my 720 gas
-remove the cap from the distributor
-drill a small 1/8 hole in the 2 or 2-1/4 inch welsh plug
-screw a metal screw in hole and pry out welsh plug with j bar
-remove cover from left side of governor housing
-pull governor drive gear to the left
-remove old plastic tach drive gear -grease shaft of gear assembly and install new gear
-push governor shaft in slowly to mesh plastic driven gear with teeth on governor shaft
-make sure gasket on governor is still good -or -replace with same thickness gasket/shim
-reinstall cover
-braze hole shut that was drilled in welsh plug if it is re-usable -hammer center of plug out into a concave shape
-re-install welsh plug and tighten with hammer striking center of plug
-install tach cable
-replace distributor cap
03-03-2013 18:58:53
 Re: JD 620 Tach drive in reply to Canadian Ken, 03-03-2013 18:27:34
Thanks Ken and Scott that is exactly what I was looking for. Sounds like a pretty straight forward job.
