| John Deere Tractors Discussion Forum |
Topic: Re: JD 620 Tach drive
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Scott 730
03-03-2013 17:21:36
75.168.204.209
620 and 630 tractor speed hour meter drive gear set AF 2709 R subs to
F 2547 R $22.06
F 2548 R $15.02
This post was edited by Scott 730 at 17:23:27 03/03/13. |
[Reply] [No Email] | |
| RMOMN
03-03-2013 17:28:12
70.97.243.96
Re: JD 620 Tach drive in reply to Scott 730, 03-03-2013 17:21:36
| Scott have you done this repair I'm wondering what it takes to replace the gears? Is the repair straight forward to do? |
| Scott 730
03-03-2013 18:39:50
75.168.204.209
Re: JD 620 Tach drive in reply to RMOMN, 03-03-2013 17:28:12
| RMOMN said: (quoted from post at 20:28:12 03/03/13) Scott have you done this repair I'm wondering what it takes to replace the gears? Is the repair straight forward to do? |
Replaced gears in my 730 diesel. I would guess the gassers would be a similar job. I had to pull the governor shaft out of the housing to replace the drive gear on the shaft. It would be wise to replace both gears. Not a good idea to mesh 1 new gear with 1 old one.
This post was edited by Scott 730 at 18:44:37 03/03/13. |
| Canadian Ken
03-03-2013 18:27:34
98.102.242.50
| | I replaced the gear on my 720 gas -remove the cap from the distributor -drill a small 1/8 hole in the 2 or 2-1/4 inch welsh plug -screw a metal screw in hole and pry out welsh plug with j bar -remove cover from left side of governor housing -pull governor drive gear to the left -remove old plastic tach drive gear -grease shaft of gear assembly and install new gear -push governor shaft in slowly to mesh plastic driven gear with teeth on governor shaft -make sure gasket on governor is still good -or -replace with same thickness gasket/shim -reinstall cover -braze hole shut that was drilled in welsh plug if it is re-usable -hammer center of plug out into a concave shape -re-install welsh plug and tighten with hammer striking center of plug -install tach cable -replace distributor cap Ken |
| RMOMN
03-03-2013 18:58:53
70.97.243.96
Re: JD 620 Tach drive in reply to Canadian Ken, 03-03-2013 18:27:34
| Thanks Ken and Scott that is exactly what I was looking for. Sounds like a pretty straight forward job. Bob |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
