TractorLinks.com
Show Parts for Model:
Re: JD 620 Tach drive
RMOMN
03-03-2013 16:59:12
What is happening is if I drive the tach cable with a drill the tach is working. Then I reattach the cable and start the tractor the tach needle is jumping all over
Tyler-MO
03-04-2013 18:54:59
 Re: JD 620 Tach drive in reply to RMOMN, 03-03-2013 16:59:12
It sounds like your little nylon tach drive gears are just about stripped off. I believe it's possible to do the job just by removing the welsh plug on the governor housing and the tach drive assembly that the cable attaches to. It will be tight, but I think you might be able to remove the snap ring and spring on the end of the governor shaft and ultimately remove the old drive gear and install the new one without removing the governor shaft...although you're going to run the risk of dropping small parts into the crankcase.
Tyler in IL
