JOHN DEERE A /60 .004 UNDER ROD BEARINGS
I've had good luck on ebay. Be patient. Place wanted ads on this site. Why remove &a grind a crank thats only slightly worn? Ask jd if they have the 0.002 unders. Likely they do, & the clearance specs are 2 to 4 thousandths i believe, so they'll most likely work fine.
Take the time to 'mic' the journals. If they are even remotely oval, do the .010" regrind. Bearings are easy to get in that size and you won't have ANY problems (unless you screw something up) for another 50+ years. HTH
I have a set of JD NOS .002 under size bearings for sale. I'll take half of what JD is asking. Thanks ,Tom. 573 535 8952
