TractorLinks.com
Show Parts for Model:
Re: JD 620 Tach drive
RMOMN
03-03-2013 16:14:29
My understanding is that there's 2 plastic gears on the shaft that drive the cable?
Bob Harvey
03-03-2013 16:43:33
 Re: JD 620 Tach drive in reply to RMOMN, 03-03-2013 16:14:29
INSIDE the tach. HTH
Scott 730
03-03-2013 17:21:36
 Re: JD 620 Tach drive in reply to Bob Harvey, 03-03-2013 16:43:33
620 and 630 tractor speed hour meter drive gear set AF 2709 R subs to F 2547 R $22.06
F 2548 R $15.02
This post was edited by Scott 730 at 17:23:27 03/03/13.
RMOMN
03-03-2013 17:28:12
 Re: JD 620 Tach drive in reply to Scott 730, 03-03-2013 17:21:36
Scott have you done this repair I'm wondering what it takes to replace the gears? Is the repair straight forward to do?
Scott 730
03-03-2013 18:39:50
 Re: JD 620 Tach drive in reply to RMOMN, 03-03-2013 17:28:12
RMOMN said: (quoted from post at 20:28:12 03/03/13) Scott have you done this repair I'm wondering what it takes to replace the gears? Is the repair straight forward to do?
Replaced gears in my 730 diesel. I would guess the gassers would be a similar job. I had to pull the governor shaft out of the housing to replace the drive gear on the shaft. It would be wise to replace both gears. Not a good idea to mesh 1 new gear with 1 old one.
This post was edited by Scott 730 at 18:44:37 03/03/13.
Canadian Ken
03-03-2013 18:27:34
I replaced the gear on my 720 gas
-remove the cap from the distributor
-drill a small 1/8 hole in the 2 or 2-1/4 inch welsh plug
-screw a metal screw in hole and pry out welsh plug with j bar
-remove cover from left side of governor housing
-pull governor drive gear to the left
-remove old plastic tach drive gear -grease shaft of gear assembly and install new gear
-push governor shaft in slowly to mesh plastic driven gear with teeth on governor shaft
-make sure gasket on governor is still good -or -replace with same thickness gasket/shim
-reinstall cover
-braze hole shut that was drilled in welsh plug if it is re-usable -hammer center of plug out into a concave shape
-re-install welsh plug and tighten with hammer striking center of plug
-install tach cable
-replace distributor cap
Ken
RMOMN
03-03-2013 18:58:53
 Re: JD 620 Tach drive in reply to Canadian Ken, 03-03-2013 18:27:34
Thanks Ken and Scott that is exactly what I was looking for. Sounds like a pretty straight forward job.
Bob
RMOMN
03-03-2013 16:59:12
What is happening is if I drive the tach cable with a drill the tach is working. Then I reattach the cable and start the tractor the tach needle is jumping all over
Tyler-MO
03-04-2013 18:54:59
 Re: JD 620 Tach drive in reply to RMOMN, 03-03-2013 16:59:12
It sounds like your little nylon tach drive gears are just about stripped off. I believe it's possible to do the job just by removing the welsh plug on the governor housing and the tach drive assembly that the cable attaches to. It will be tight, but I think you might be able to remove the snap ring and spring on the end of the governor shaft and ultimately remove the old drive gear and install the new one without removing the governor shaft...although you're going to run the risk of dropping small parts into the crankcase.
Tyler in IL
