Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
adding powertrol to 1941 B
carterbeauford
03-03-2013 07:37:27
I have a 1941 B with power lift. can I add powertrol with just a housing swap?
I found this picture on here, this is what I'd like to do.
carterbeauford
03-09-2013 06:54:38
 Re: adding powertrol to 1941 B in reply to carterbeauford, 03-03-2013 07:37:27
http://www.ebay.com/itm/John-Deere-A-B-G-Power-Trol-Box-/290833939092?pt=LH_DefaultDomain_0&hash=item43b70dba94
I am thinking of buying this housing, which part number plugs will fit? do the plugs just lock in place when you push them in? thanks, new to this.
carterbeauford
03-03-2013 14:07:20
right
carterbeauford
03-03-2013 12:50:19
excellent, I spent a lot of money on the big housing and installed a new main gasket and PTO seals so I wasn't looking forward to having to replace it.
I don't use the power lift, can I install the threaded plugs and use modern hydraulic couplers?
bigboreG
03-03-2013 13:25:37
 Re: adding powertrol to 1941 B in reply to carterbeauford, 03-03-2013 12:50:19
Yes. Your talking about pioneer couplers right?
carterbeauford
03-03-2013 08:19:56
are we referring to the small housing or the complete rockshaft/differential cover housing?
bigboreG
03-03-2013 08:30:58
 Re: adding powertrol to 1941 B in reply to carterbeauford, 03-03-2013 08:19:56
You will need the gasket though. If your careful you may be able to reuse the old one, but I suggest a new one.
bigboreG
03-03-2013 08:25:37
The small housing. The powrtrol will bolt right on. Even a housing from a 50 will bolt on and work. I put one from a 70 on an early A and have used it alot with no problems.
bigboreG
03-03-2013 07:58:02
Yes. Just find a complete powertrol housing and unbolt your old one. Swap em out and your done. I have done 5 or six, nothing to it.
Kent Petersen
03-03-2013 15:30:36
 Re: adding powertrol to 1941 B in reply to bigboreG, 03-03-2013 07:58:02
you need the bottom stud from the the donor tractor as the powerlift one is to long
