| John Deere Tractors Discussion Forum |
Topic: The Clutch is Out of the 47 A
[Return to Forum]
| Author |
[Modern View]
| oldmanandakid
03-02-2013 18:44:39
70.34.5.2
Success but what happens now? What should I be looking for with the disassembled clutch? Obvious things include broken and worn plates, worn and rusty adjustment springs, no cone washers. Do the driver faces need to be resurfaced or can I just clean them up and reinstall? Only one of the toggles seems badly worn but I have no point of reference for the dogs although the bottoms of the cups are thinner than the rest of the cups. Are toggles and dogs JD parts or is there another source and should I replace the entire set?
I have a pile of parts and sure could use some direction. Thanks again guys. By the way, after being under pressure overnight it took just a couple of more turns to pop the driver loose. |
[Reply] [No Email] | |
| oldmanandakid
03-07-2013 12:48:49
70.34.5.2
Re: The Clutch is Out of the 47 A in reply to oldmanandakid, 03-02-2013 18:44:39
| It looked like I was cruising to an easy and relativity cheap clutch repair until the flapper wheel revealed cracks in the both the driver and adjustment plate. I'll probably spring for a new driver but am wondering if the ductile iron adjustment plate is worth the money or a good used one would suffice.
Thanks again guys. |
| Lee B
03-05-2013 07:17:10
64.37.30.36
| I would suggest you go back with every thing cleaned up and lubed. If it needs something after a bit of a work out, THEN spend some money as needed. Right now, you don't know what that is right? You'll have a much better idea of that later. |
| alvan
03-03-2013 08:06:17
65.185.14.200
| Sharpe"s antique tractor parts has everything you need to rebuild your clutch. New dogs clutch facing Google sharps tractor parts to get their web site super nice people I have bought a lot from them at great prices. |
| bigboreG
03-03-2013 08:20:24
166.181.3.34
Re: The Clutch is Out of the 47 A in reply to alvan, 03-03-2013 08:06:17
| Alvan I second Sharps as well. I get alot from them too. |
| bigboreG
03-03-2013 08:04:35
166.181.3.192
| Clean the driver up good with a wire wheel and follow up with a flap disk. If its pitted bad then you may want to find another, also look for cracks as later As tend to have problems with that. The parts you need can be found aftermarket, look on YT maybe. If not here, check out Contrary Acres. I get clutch parts from him and have been satisfied. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
