4020 rear wheel
robert3239
New User
I have some wobble on my rear wheels, one can see i high gear not rotating straight. Tires are radial with age and have fluid in them. Where does one start on something like this? Would the dealer do the best job?
And where does one find replacement rims?
Thanks
Robert
Jack up tractor and loosen the bolts on the outside that hold the wedges tight then re-tighten in an alternating sequence while turning wheel with a block of wood on the ground/floor as a guide. BTDT many times
as Jim says. when properly adjusted, you will have about the same amount of threads showing past the nut on each bolt.
