| John Deere Tractors Discussion Forum |
Topic: 47 A Engine Free-Cluth Stuck
[Return to Forum]
| Author |
[Modern View]
| oldmanandakid
02-28-2013 17:42:12
70.34.5.2
Since freeing up the engine we are now unable to engage the clutch. While the engine was frozen the clutch would engage with a firm push now it is impossible. Ideas and help appreciated. |
| clampdaddy
03-01-2013 21:16:23
50.8.151.226
Re: 47 A Engine Free-Cluth Stuck in reply to oldmanandakid, 02-28-2013 17:42:12
| Put the bolt & washer back in the end of the crank, leave it a couple turns loose, make sure the pressure on the two half inch bolts is pretty even, and give the head of the center bolt a sharp whack with a ball pein hammer. Normally pops 'em loose on the first couple whacks. |
| oldmanandakid
03-01-2013 20:02:20
70.34.5.2
| | Update. I started the tear down today but quickly stalled when trying to remove the driving disc. First I tried with a gear puller then tried using the JD method of inserting 1/2 bolts in the disc keyholes and turning against the interior clutch facing. Neither worked and I left the bolts under tension for the night. What about using a torch to heat the driving disc where it attaches to the crank? The clutch appears to be completely burned up. Even after all of these years there was a strong burn smell and the pulley body was filled with black. The outer facing had a big chunk missing however the clutch lever snapped over nicely when I loosened the adjusting nuts. Does it sound like any part of this assembly will be salvageable? But first I need suggestions about further disassembly. Thanks for the help guys. |
| Mike Aylward
03-01-2013 09:01:30
209.152.135.126
| It's not unusual for a tractor that has sat for a time (especially in high humidity conditions) for the clutch operating bolts to freeze in their bores. You will need to remove the pulley and clean everything. This probably needs done anyway. Clean all the parts, put a little anti-seize in the clutch bolt bores, and adjust and replace. Mike |
| greenday
03-01-2013 04:39:15
204.185.166.101
| You could have possibly knocked a bunch of rust loose in the clutch facings and driver which is not letting it engage properly |
| A GURU
03-01-2013 04:20:02
184.96.116.138
| Is the clutch actually stuck in that it can't be rotated, or is it that there simply is no "snap" anymore? Is it possible that once you freed the crank there was so much end play in it that the clutch needs readjustment to engage? Just a thought. If it is stuck then it will likely need torn down to repair. |
| bigboreG
02-28-2013 20:53:04
166.181.3.168
| Take the clutch apart and inspect all the parts. Something is binding or is broken. The operating fork could be slipped past the sleeve if things are wore bad enough. Or it could be as simple as too much tension on the adjusting nuts. Lots of rust and black powder will mean a complete clutch job. Keep us posted. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
