TractorLinks.com
Show Parts for Model:
Re: 4010 would not crank back update again
Tx Jim
02-28-2013 16:37:40
I'll bet pull starting is spinning the engine a lot faster than the starter is. How long since inj pump timing has been checked??
This post was edited by Tx Jim at 16:40:00 02/28/13.
Mtractor
02-28-2013 17:09:42
 Re: 4010 would not crank back update again in reply to Tx Jim, 02-28-2013 16:37:40
I even put 24 volt to the starter that should turn it fast enough . I have not checked the timing what is the best way to do that?
Tx Jim
03-01-2013 04:19:12
 Re: 4010 would not crank back update again in reply to Mtractor, 02-28-2013 17:09:42
Remove timing windows on clutch housing & inj pump. Turn engine with a large screwdriver or bar in the direction it runs until timing marks on flywheel appear in slot. 4010's time at 14 degrees BTDC IIRC
