TractorLinks.com
Show Parts for Model:
Re: 4020 clutch pedal slot adjustment
belaw
02-28-2013 08:26:33
Tx Jim said: (quoted from post at 05:15:04 12/10/09)
msb said: (quoted from post at 00:19:49 12/10/09) . As the disk wears the fingers get closer to the TO bearing, so you need to move the adjustment bolt forward to increase the free travel.
msb
It's been a long time since I adjusted a clutch pedal on a 4020 but I was thinking one moved the bolt towards rear of slot to give more free travel.
Sorry for dragging up an old thread, but I didn't see any point in starting a new one. I just purchased a '68 4020 that has almost no freeplay. Right now the adjusting bolt is about 2/3 of the way down the slot.
To gain more freeplay do I move the bolt to the bottom of the slot or the top? To ask the same question another way, do I have 1/3 or 2/3 of my adjustment range left?
FWIW the seller says that there's about 1,500 hours on the clutch.
This post was edited by belaw at 08:28:02 02/28/13.
Doug in IL
03-01-2013 11:35:58
 Re: 4020 clutch pedal slot adjustment in reply to belaw, 02-28-2013 08:26:33
You have 2/3rds left to go.
Tx Jim
02-28-2013 09:20:16
To gain more pedal free play move bolt in the slot towards the rear of tractor
belaw
02-28-2013 11:23:35
 Re: 4020 clutch pedal slot adjustment in reply to Tx Jim, 02-28-2013 09:20:16
Great, looks like I have over half of my adjustment range left.
Tim S
02-28-2013 11:46:52
 Re: 4020 clutch pedal slot adjustment in reply to belaw, 02-28-2013 11:23:35
Most of the clutches that I replace is because they were ran with no free travel,,regular clutch pedal adjustments can save a lot of $$$
jc okla
02-28-2013 09:03:52
1/3
