700 high boy
JWalker
Does anyone know the weight and length of a John Deere 700 Hi-Cycle. I am considering one that is about 150 miles from home. I have a trailer that is 16' long and I am not sure if it will fit on the trailer or if it weights too much for my trailer. I have checked TractorData but it is not listed.
Also what is a ball park value for this tractor. It has good tires, supposed good motor. Needs alternator, pump is good, but needs seal around piston replaced.
Sorry I do not have any more info.
Many Thanks
JWalker
I am assuming you are talking about a sprayer.If so those were set on 38 inch rows so I would quess it would be less than 8 ft wide.Weight would be similar to a tractor of that size or less.The booms folded along the sides.If it is just a light duty car trailer I would look for something a little larger.Those sprayers towed well at around 35MPH.max.We had a 734 before the 6000 series and there are a few left that havent been scrapped.We had a trailer that we hauled ours on that just had three rails and a tandem axle.I hauled a 6000 from Neb. on my machinery trailer and it had to be narrow and was tall as it had cab but worked fine.
Here are the owners manual specs for the 700 self propelled sprayer. Weight - 3850 lbs. Wheel base - 90 inches. Overall width - 94 inches. ( tire to tire ) Length - 139 inches. ( tire to tire ) Length - 183 inches. ( front wheel shield to rear of lift arms )
