Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Tx Jim
[Return to Forum]
rustidiot
02-25-2013 21:25:32
67.142.168.137
I looked at the 1020 and there is no lever between the shift levers. The pto lever is down on the left side of the case. The pto turns real slow when engaged and you can stop it easily with your shoe. Fill the little reservoir ahead of the radiator, drive a couple of miles and the steering and 3 point quits working. Fill it again and do another couple of miles. Tractor runs great.
Thanks,
Rustidiot
[Reply]   [No Email]
cannonball
02-26-2013 05:33:14
98.20.35.16
 Re: Tx Jim in reply to rustidiot, 02-25-2013 21:25:32
Have you cleaned screen and changed filter...If front pump works for 2 miles when you fill up reservoir then your trans pump is not feeding front pump...do you have hi lo ...if not you have pump or line problems internal...Tx Jim probably nailed it on clutch...
[Reply]  [No Email]
Tx Jim
02-26-2013 03:55:24
67.142.163.23
 Re: Tx Jim in reply to Jason S., 02-25-2013 21:25:32
Sounds as if tractor has a continuous running(dual stage) pto that the pto clutch is slipping. The slipping clutch could be contributing to weak hyd's. How long since hyd oil filter was changed & sump screen checked/cleaned? Look inside hyd filler hole in MSD's photo with engine running,3pt raised for spraying oil. Those type JD tractors have a history of the RS valves seal leaking causing hyd problems.
[Reply]  [No Email]
MSD
02-25-2013 22:14:38
71.209.114.142
You fill the hydraulic system in the rear. The grey cap is where it goes in. You check the level on the right side floor board. Should be a 1" cap you can unscrew and it will have a dipstick attached. The tank in the front will stay full when the rest of the system is full.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
