Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Crankshaft splines options
[Show Entire Topic]  [Return to Forum]
Rwolfejr
02-25-2013 13:14:04
67.163.184.160
Don't know about the B's but the R's 820's etc. are all a tapered spline on the clutch driver assembly. I would GUESS... that you should be able to come home with the splines you have but it would reposition your driver by whatever amount you're worn. If the tapered pair won't come home and lock up you need to see what is causing them to not go all the way home. Could be that a slight counter bore on the driver might allow the pair to smack up tight. Then you'd need to look at the assembly and see what effect that slighly different home point might cause for other components.
For example it might have the driver running into the main bearing housing? Might need to dust the face and run the seal bore in a bit? I really doubt it'd move that far and would guess you'd be fine.
The other option for a "once in a while" tractor... Would be to make shims for one side of each spline with bent tabs at the bolt down end. (To try to help them from being completely sucked in when tightening) Start the driver on loose... Stuff thin beer can shims along one side / same side of each tooth.... shims cut tapered so they don't hit the root (small diameter at the crank direction of the spline) of the splines... then run it home. Shim is a wonderful thing... !!
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
