TractorLinks.com
Show Parts for Model:
Re: TxJim Fitting photos 4020 loader
Tx Jim
02-25-2013 10:13:50
John
This should be he spec's for the tee. Maybe this will help someone in the future that's attempting to plumb a loader valve.
Part Number: AK40462
Part Price: 36.33 CAD
Description: TEE - O RING BOSS
Specification
Weight 0.88 LBS 0.40 Kg
Tube Outside Diameter 0.750 IN
Thread Size 1.062 IN
Length 1.640 IN
Length 1.920 IN
Length 1.620 IN
Roger in Iowa
02-25-2013 11:02:02
 Re: TxJim Fitting photos 4020 loader in reply to Tx Jim, 02-25-2013 10:13:50
Thanks Jim for the tee part number. We are working on a 4020 now!
roger
Tx Jim
02-25-2013 11:18:03
 Re: TxJim Fitting photos 4020 loader in reply to Roger in Iowa, 02-25-2013 11:02:02
Roger
You need to thank long green line man for the part # as he posted the part # on another thread. I thought I would post the part# & spec's along with John's(nylon4020) photo's for future reference to hopefully make it easier for a conversion.
Roger in Iowa
02-25-2013 18:17:41
 Re: TxJim Fitting photos 4020 loader in reply to Tx Jim, 02-25-2013 11:18:03
What is the part mumber for the tee at the rockshaft housing?
Tx Jim
02-26-2013 04:10:12
 Re: TxJim Fitting photos 4020 loader in reply to Roger in Iowa, 02-25-2013 18:17:41
Roger
I don't have the part # but this is the spec's on the "L" fitting that requires replacement.
Maybe Mike M will post the part number.
If it was my tractor without a cab I'd R&R the fitting just in frt of the brake pedal on the other end of the RS supply line in the photo.
Part Number: AR35712
Description: ELBOW,90 DEGREE,ADJUSTABLE
Specification
Weight 0.35 LBS 0.16 Kg
Tube Outside Diameter 0.625 IN
Thread Size 0.875 IN
Length 1.449 IN
Length 2.079 IN
Length 0.500 IN
long green line man
02-26-2013 06:09:03
 Re: TxJim Fitting photos 4020 loader in reply to Tx Jim, 02-26-2013 04:10:12
Tee part# AN140264 , should work on ether end of RS line .. AN 140263 or AN 140265 should give one smaller or larger port to att. flange tread HYD. hose too....
Roger in Iowa
02-26-2013 07:15:16
 Re: TxJim Fitting photos 4020 loader in reply to long green line man, 02-26-2013 06:09:03
Thanks Jim and Long Green!
