Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 70 Flywheel
02-20-2013 16:04:14
Report to Moderator my experience a cracked flywheel is the result of it coming loose and then overtightened in an effort to keep from knocking. Although the splines may look good on the crank they are probably slightly worn and a taperlock is the best way to fix the problem. Putting a used or NOS JD flywheel on a worn crank will not work. You cannot have any radial movement of the FW on the crank (spline/groove width worn) or vertical movement (over diameter of the crank worn). If you go with the taperlock, make sure you follow the installation instructions closely.
