fuel in oil
I solved that problem with my 2040 by replacing the lift pump. I thought it had to be either that or the injector pump causing my problem.
Butch
Use two wrenches, remove all injection lines at injection pump. Now retorque pump delivery valve fittings, 22-25 ft-lb and replace all lines. This is worth a try before pump is removed for complete reseal. This pump has copper gaskets under the barrels that can leak, may just need retorqued again. Most inline pumps do not seal like this model does.
